STM PowerSports Clutch Products & MAJOR POLARIS ISSUES
By BuckBilly
By ATVNetwork
By P_syko
By marcosphoto
Hi folks, a little disparity brought me to this forum. To set the stage, I'm a 35 auto tech in the industry 37 years now. Licensed motorcycle tech also, 20+ years. I race superbike and motocross. Always done most of my own standard work (outside of specific race machine works) including building my own race bike engines. Now that skills are out of the way, onwards and upwards.
Helping a neighbor with his old quest 500, right front axle seal leak. Well, looks like everything else - right? Wrong! Initially I noticed the CV joint was lacking large lands to place prybars on to pop it out, rather a thin shield like ring very close to the diff seal. Knowing the ring appeared quite delicate, I only pried gently and the CV popped out. However this is where things get weird. Came out only around 7-9mm then hung up again, felt like the clip was catching inside the diff. So spun and pulled, spun and pulled until I was blue in the face but no success getting it out. Also while it was out, I could see that the delicate ring around the outer circumference of the joint was actually the sealing surface where the seal contacts, instead of the norm where the seal rubs inside the diff much deeper and stays cleaner. I've never seen a joint like this, also the service manuals photos which apply to 650 also reflected a standard joint I am accustomed to rather than this one I was fighting with. Rather than break something in the diff, I decided to stop while I was ahead and reassemble the machine before something broke. (The joint would pop in and out of place easy enough, just wouldn't slide out further than 7-9mm). While the joint was a little out and sealing surface exposed, I cleaned the seal and sealing surfaces clean as possible before putting back together. Seems to be holding for now, but eventually I'm sure the leak will come back. Any thoughts as to why that CV joint just refused to come all the way out?
By quadcrazy
Covers the following models:
1985 Scrambler Trail Boss
1986 Scrambler
1986 Trail Boss
1986 Scrambler
1986 Trail Boss
1987 Trail Boss
1987 Cyclone
1987 Trail Boss 4x4
1987 Trail Boss 4x4
1987 Trail Boss 4x4
1988 Trail Boss 2x4
1988 Trail Boss 4x4
1988 Trail Boss 250 RIES
1989 Trail Boss
1989 Trail Boss 2x4
1989 Trail Boss 4x4
1989 Big Boss 4x6
1989 Big Boss 4x6
1990 Trail Blazer
1990 Trail Boss 250
1990 Trail Boss 2x4
1990 Trail Boss 2x4 350L
1990 Trail Boss 4x4
1990 Trail Boss 4x4 350L
1990 Big Boss 4x6
1991 Trail Blazer
1991 Trail Boss 250
1991 Trail Boss 2x4
1991 Trail Boss 2x4 350L
1991 Trail Boss 4x4
1991 Trail Boss 4x4 350L
1991 Big Boss 4x6
1991 Big Boss 6x6
1992 Trail Blazer
1992 Trail Boss 250
1992 Trail Boss 2x4
1992 Trail Boss 2x4 350L
1992 Trail Boss 4x4
1992 Trail Boss 4x4 350L
1992 Big Boss 4x6
1992 Big Boss 6x6
1993 2502x4
1993 3502x4
1993 2504x4
1993 3504x4
1993 Sportsman
1993 2506x6
1993 3506x6
1993 Trail Boss
1993 Trail Blazer
1994 3002x4
1994 4002x4
1994 3004x4
1994 4004x4
1994 3006x6
1994 4006x6
1994 Trail Boss 2W
1994 Trail Blazer 2W
1994 Sportsman 4x4
1994 Sport
1995 3002x4
1995 4002x4
1995 3004x4
1995 Xplorer4x4
1995 4006x6
1995 Trail Boss
1995 Trail Blazer
1995 Sportsman 4x4
1995 Scrambler
1995 Magnum 2x4
1995 Magnum 4x4
1995 Sport
