1994 Quadrunner LT-F160 rear axle seized up.
By pastorjeep
Ok guys, I am a glutton for punishment! I picked up this 01 2wd Rancher because the plastics looked good on the marketplace. It has been sitting in the guys back yard for 10 years. The original engine blew and they swapped in an electric shift 4x4 engine. 😒The engine is locked up and was full of water. The wiring is hacked where they tried to get it to run and the rear end needs new swingarm bearings where they left it laying on the ground in the woods for 10 years. Has anyone here ever did the engine swap? First thing is to straighten out the wiring and get the engine free to see if I can get it to crank over. I have swingarm bearings ordered and a new ignition switch. So hopefully I can at least roll it around soon. 🤣
By motox88
Anyone have bad experience with these clutch kits? Looking to get one for an 80s quad that I have.
By geezer99
I have an Axis 500 made by Hisun. I uses a solid rear gearbox with no differential action.
I would like to convert this to a true differential with locking ability. I've searched all over trying to find a source with no luck.
Has anyone done this before, or know of a source?
Thanks, Tom
By DaveswMN
Thanks for any thoughts.
By Chucksta
Any ideas?
