It’s been a year of swapping and fixing and swapping and fixing and swapping….
Last year I bought a KFX80 mouse condominium for $500,
B7D653FA-8DA2-421B-9A55-7C8E326E4778.thumb.jpeg.1cd72fce8f64ea90988e703d0b94d583.jpeg2833097E-E488-4990-B829-CC72089A83C1.thumb.jpeg.65e100ed68c9015189f7c10993cce866.jpeg
fixed it and swapped for a Blaster,
18C44C8C-5EF6-43FF-B09D-4DD5CC61F2B9.jpeg.a081ac9ac3ef9a2b63f5990faedb7bba.jpeg5B13D0D4-6120-49C1-B52C-3A609CD55033.thumb.jpeg.89fdb06ed596f3755f313e0812168027.jpeg
fixed that and swapped for a LT230s,
A9202E4A-2A4B-4D6E-8EE1-93DFC308AFE8.thumb.jpeg.8dfc4bc5c21dbb116bad7ff791f5de28.jpeg9D3BF326-A689-4072-8333-EA9972AE317D.thumb.jpeg.f6d06a3b3f5de131cbae49f944c14de7.jpeg
straightened that out and swapped for an ‘07 KX 85,
cleaned THAT up and traded it for a clapped out LTZ400 with OMF bead locks, ELKA shocks, HotCams, ProTaper bars,
C3A18696-4B7B-4E6A-8867-0602B35D8279.thumb.jpeg.b3350c94e56dd2f6ca9a7052bad3bab0.jpeg3BC5CB6D-9D6A-41CF-A9D9-F6DF7D35505C.thumb.jpeg.48410117f57aaa48311a018faf324d25.jpeg44C9C3E3-F4DF-4FCA-A309-53168C80D69B.thumb.jpeg.ac9dc30ccb49c6b180667d15cb797386.jpeg3BC23677-9ABB-4ACF-ACCE-DF4FE9B58F8C.thumb.jpeg.0ef2bf47c14d6b57e76fdcc399fcfda9.jpeg
and a serious case of “PO had no clue what they were doing”.
5E3F6E1E-695A-4527-BFC5-DE2EBFDF97A8.thumb.jpeg.4ff3049a3e84354fe0b62aa54ca45062.jpegFE4A5A8F-8E04-48E3-B6C7-5FAF48856DB2.thumb.jpeg.4ceca1355435bb461e44f71f571632e8.jpeg
I recently posted about finishing up that LT160/230,
well almost finished - timing was off for some reason, but before I could get it figured out I found someone to swap it with for a 94 XR200R with a strange ticking in the head.
Replaced it’s timing chain and guides, re-tensioned, popped out the valves and cleaned them all up, all back together and the ticking persists.  Flipping thru the Clymer manual that came with it I found a stacked head gasket tucked inside. And saw a green paper one on the bike. 💡
So anyway, I traded it to someone more inclined toward two-wheeled adventures for an awfully clapped out DVX400 with a lot of Alba’s finest red anodized aluminum ding dongs all over it. And a Houser chromoly stem! AND a big bore kit (JE Piston).
PO couldn’t get it to run, which turned out to be a combination of 4 stripped threads in the cam journals, and a “twist n’ tape” job on the damn stator wires. 😳😝🤣
After a few weeks of wrenching and part swapping and fixing and sweating and swearing and parting out - I nearly have a drivable quad… and a pretty damned nice one for my tastes at least.
Thinking about sinking a few hundred Kold Kutters into this extra set of tires and having a go at the ice this winter ;)
    • By Sportsman500guy
    • By qcm413
      Hi,
      thank in advance
    • By marcosphoto
    • By Mmessy83
      I recently purchased a complete lt230s for$50. It was missing the kick starter gears which I got off eBay for $18. I’m trying to install the gears which after reading different threads about having it timed. I have it all timed but now it acts like engine is seized up but I know it’s not. What could be going on??? Any insight would greatly be appreciated.
