What is everyone using for aftermarket brake hoses?
I need to replace one hose from "T" to left brake caliper (59240-22A04), probably just replace both sides and the master cylinder to "T" hose (59480-35B01) also.
OEM part numbers not available, Ebay only has preowned that are $$$.
Would really like to install stainless hoses.
Are the hoses standard? Can I use Honda hoses etc.?
59240-22A04https://www.mickhone.com.au/partFinder/fiche/suzuki/1993/lt-f250/front-brake-hose#partid-45245403
I wonder if these would fit.. LT250.. it's the nearest we have here.. If they have a price, they should be available.
If you go to that site you can choose a part and then click an arrow over on the right and it shows you what other models the part fits, and/or even better for you, in a diagram page, if you go to the top of the diagram and enter your part number(Search for part.. 59240-22A04), in the search box there, it will drop down a long list of comparable parts.. There's another search box at the top of the page but it searches the whole site, it doesn't come up with the drop down list.
Thank you Mech,
Looks like no stock in store or supplier at least for the part numbers I am hunting, I'll keep checking back.
I can't imagine why the ends would be different for other models at least within the same manufacturer.
Hopefully someone with more expertise than I have will be able to point me in the right direction.
    • By DPDISXR4Ti
      Thanks...
    • By carkivey3
    • By EasyE
