92 moto4 shifting issues
Go to solution Solved by Mech,
just picked up a 92 grey moto4 350 runs great, but has major shifting issues, I believe it shifts into 3rd gear and 5th gear, but if you shift all the way to 5th gear first then back down to first then first gear might work but then nothing for second then 3rd will catch.
So do you feel this is a clutch issue or is the trans pretty much shot, I figured if I have to tear into the trans then just rebuild the motor this winter, but if it's just clutch parts repair it now and have fun with it.
Thank you for any reply
Drain the oil and use a magnet to find bit's of metal.. Flakes, chunks, dust..
It might be blown gears, but it might be something simpler, in the gearchange linkages.. inside the side case if you were lucky, rather than deep inside..haha.
ok took it all apart split the case and guess what issues I found...... nothing everything looks good I even bought used transmission parts
to replace any broken parts.
Now the question before I put it back together is there a certain place the gears should be? Or do i put it back together and after everything is back on It will know
what gear it should be in (I can't really explain what I want to say).
Last thing I can't seem to find a case gasket for it so what do you use for the cases?
  • Solution
The workshop manual will tell you exactly where and which way each gear should be on it's shaft, with spacers etc, and which shift fork goes where.
The cases don't have a gasket, just sealer, and I'd highly recommend you buy a tube of loctite master gasket and use.. It's clean to use and doesn't leave long strands of squeezed out silicon inside the engine to block the filters..  It doesn't really matter what gear it's in as you assemble the cases(if that was the question).
As for the gear shift, I'd put the center cases together temporarily and try every gear change by turning the shift barrel from in the side case, whilst turning the two gear shafts. It would be good to have the lever and wheel in the side case that rubs on the shift barrel and holds it in each gear. That wheel both holds it in a gear once selected, but also makes sure the shift travels all the way into gear if you don't move the shift lever full travel. The shift barrel may be a little tight to turn if it's all dry in there, but you should be able to turn it with your fingers as long as you turn the shafts enough. Sometimes you will need to turn the shafts quite a few turns to allow the cogs to line up and engage, but they should all slip nicely from one gear to the next with enough turning of one or both shafts. Be patient, test it carefully up and down through all the gears.
If you can get all the gears at that point, it suggests the problem is in the outer/side case, something in the shift mechanism before it gets to the shift barrel. Possibly the return spring on the lever, or the spring on the ratchet mechanism, or the ratchet mechanism itself.
Post photos if it's easier than trying to describe things, or, get the manual or look things up in an online parts place, and describe parts as the book does.
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By Frank Angerano
