Connecticut
By BuckBilly
By kawasig
Hello there
By mga
I see quite a few ads for that Tribotex additive. It's kind of expensive, has anyone used it it their ATV or any other vehicle?
By Brantley11
Hey everybody,
My proficiency is with Hondas and Yamahas make me see RED!
This bike is my brother in law's, it has 1199 miles on it and went from running great to dead with no start. Every once and a while it will start and sputter for 2 seconds. It is extremely sporadic when it fires but never runs for longer than 3 seconds.
Here is where we sit:
Brand New Fully Charged battery
Carb was cleaned with air hose and carb cleaner then into the ultrasonic cleaner with Aircraft aluminum cleaner
New Shindy Carb kit (made in Japan version)
Cleaned out petcock and gas tank
New 93 Non Ethanol Gas
New Spark Plug
It gets a spark through the spark test light every time
Bluish white spark
When holding the spark plug 1/4" - 3/8" away from head it will jump and spark to the head
Good Compression
Here are the readings:
Pickup Coil 519 Ohms (range 459-561)
Charging Coil 266 Ohms (range 270-330)
Lighting Coil 0.700 (range 0.702-0.858)
Spark plug Cap 10.58 Ohms (10kohms
Ignition Coil Primary Coil 0.5 ohms (range 0.18-0.28 ohms)
Ignition Coil Secondary Coil 8.20 kOhms (range 6.32-9.48 kOhms)
Would y'all think stator and pick up coil, rectifier or CDI are the culprit?
By DarkRider
Hey everybody,
Just curious on some opinions on my recent buy. I'm a big fan of the drivetrain and transmission in the Suzuki King Quad 300 and QuadRunner 250 4wd models. I've been wanting one of either model for quite some time, and recently picked up a really nice shape one for 1500. I just wanted to get some opinions on whether you'd be more hesitant to get something this old, if there are newer options that are comparable.
Also just keep in mind this is coming from someone not super mechanical.
Key factors:
Engine doesn't appear to have any leaks Had to replace the battery for $100, no biggie Front left CV boot is torn (not yet sure if the axle has damage) Starts right up with the tap of the button every time (so far) Idle was a bit low and was shutting off when warm. Adjusted the idle. Now it will only shut off occasionally on a hill if I'm not rolling or giving it gas. Has a Harbor Freight Badland winch with a wireless remote (brand new, tested and working) Has brand new shocks and brakes Shifting gears and changing between 2wd/4wd/diff lock/high/low/super low all seem fine. Rides pretty good, tight steering, takes the bumps pretty good as I have pretty rough trails. Brand new tires Over 2000 miles, that's quite a bit, but it seems well cared for. Plastics are almost all there. It's really only missing a small bit of the black mud flap in the rear. Has minimal stitching in the front, and it's got the usual scuffs. All of the lights work just fine (Neutral, Reverse, high and low beams) Tested the charging system and that works
And I think that's just about all I can think of at the moment. It mostly seems to be complete and all there. I was a little hesitant about getting something that old, as parts are always a concern. Looks like most parts are available, but axles seem to be hard to get if you want something brand new. I really wanted a 2000's model but I couldn't pass up the price.
