Hello everyone!  Just joined up.  I've had a Kawaski Bayou KLF300 2x4 since my Dad bought it new in '86 (nearly as old as I am), done a lot to keep it running through the years, especially with starter motor and carburetor work.  I'm a veteran at cleaning the finicky CVK-32 carb, everytime I get idle hard start problems its drain the float bowl, and if no go then clean the carb, done that a dozen times over the years now.  Still in pretty good condition, kept out of the rain much its life, still runs like a Swiss watch starts right up, though now needs a bit of ether to get going if it's much below freezing.
I have a video I made on how to replace the starter motor quickly without removing the engine side cover or even draining the oil, so for my first post thought I'd post it here to help everyone else.  If someone needs a hand with this machine drop me a line!
I'm also working on a 1993 Suzuki QuadRunner 300 for a friend, could use a bit of help with that so I've made a separate topic here:
Thanks everyone, cheers!~
Bellarmine
    • By Kawasakibayounospark
    • By neilroy87
    • By beast6228
      However, last night I was looking at the service manual and noticed that it mentioned that this atv has a crankcase breather tube as well. Mine does not have one, so I looked at Partzilla and looked at the parts diagram and sure enough, it's definitely supposed to have one. The problem however is, the service manual does not show how it hooks up and the parts diagram only shows the exploded view of the assembly. I just find that kind of strange, nowhere in the manual does it show how it connects. Does it have it connector, attach to a nipple? It just doesn't say and it bothers me that there is a hole there without anything attached to it.  If anyone has a Bayou 300 or Lakota 300 with an intact breather vent system and could possibly take some clear photos of it or know how it connects I would be very grateful. I have searched high and low and cannot find any information on it.
      Adding to downloads library.
