Quick question about bolt on valve cover (circled). Is this used for any type adjustment or connected to anything or is it a service vacuum port? Wanting to install a vacuum fuel pump and look like a good spot to connect vacuum. Thanks to all.
The way it's angled in it could be a tacho drive option, blanked off, or it could be an oil feed/pressure check point..
It will pretty surely not be a place to get vacuum. You really want to draw vacuum straight off the manifold, that's the black bit on the back of the head, or a vacuum port off the carburetor.
If that make? has a part list online, you could look up the pictures and identify parts, and see if that bolt has anything under it.
Thanks gang. Next down day is Wednesday so I will mad the intake with a vacuum port and report back. This Blaster is so beyond modded nothing is out of play at this pont!
    • By Tim Keiper
    • By oxidized_black
    • By leecon
