I have a 1986 quadrunner 230 GE so the problem is I can not get any pressure in front brake lever I know this means a leak possibly or air  but i opened all wheel cylinders and found one with a torn dust cover i had a spare cover and then pulled calipers soaked in brake fluid reinstalled amd still no pressure I can get fluid to come out of bleeders at wheels but cant build pressure Should and what if anything should i chk at master cylinder ? thanks guys
Those dust covers aren't going to do much good with that gap between them and the cylinder. And the pistons look pretty dirty too ?
I presume you did have the brake drum on when you were bleeding the brakes. I'd check at the master cylinder that there was actually pressure. I'd take the pipe/hose off somewhere and block it with my thumb and try pumping fluid through. If it got fluid, and some pressure, then I'd reconnect and try bleeding at the wheels. It's always a good idea to pump the lever up to as much pressure as you can, then undo the bleeder suddenly so you get a fast flush of fluid through, which will carry the air with it. If you pump slowly, or open the bleeder slowly, an air bubble can rise up against the downward flow of fluid.
I think though that you need to check the condition of those cylinders.. The springs should pull the pistons back in.. the rubber boots should fit, and stay over the cylinders. I'd get two screwdrivers and hook them into the backing plate and pressing against the brake shoes, and then keeping pressure on both shoes, I'd lever them both right in, then from side to side a little to make sure they moved nicely.
this was before cleaning cylinders and changing dust covers i have cleaned them replaced dust covers and have them looking pretty nice and sealed now Witch is what i thought would fix the problem im going to do a reverse bleed and see what i can get .I know the cylinders are moving good also I used some fine emory cloth and cleaned them up soaked them in brake fluid and they seemed to be good i do have new springs coming also im going to do what u mentioned to chk hose for leaks but im almost positive there is no leak Maybe the drum was not seated against the wheel back plate as good as it should be ill chk on this as wheels are still off thanks will post results
Edited by tjakes680
I also see the adjusters are right back in. Are you sure they were adjusted out correctly when you were trying to bleed and get pressure. You might have trouble bleeding, or getting pressure, if the shoes have to move too far before they contact the drum.
  • Thanks 1
The adjusters should be ok the wheel is spinning freely  but good point ill look into that its difficult to find any parts at all for these brakes I did manage to find some new springs these were rusty and very tight i dont know if thats a problem
5 minutes ago, LesterL said:
Im having similar issues, guess I need to pull the drums off and look at mine now.... 🙂
yes I found some new caliper inserts and duat covers from a 85 and 87 lt 230 but now i have to rebuild my master cylinder i just been so busy this summer but was planning on getting on it this week now that summers over u can find a MC replacement for 20$ on ebay
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By Mhatayas
      Adding to downloads library.
