Artic Cat 400 4x4 400 has strange problems
Go to solution Solved by mikeexplorer,
I let my ArticCat sit over the winter but before it was put in the garage it was running perfect. In taking it out this year it wouldn't start. I can start it with a charger and it will idle just fine. But it's doing something weird now. Either the display 1)won't display anything or 2) it will just display the analog speedometer but none of the digital stuff or 3) it will display all. So it was acting really sluggish when in HIGH gear and sounded like it was in low gear. So in driving it down the road and it being sluggish, I switched the ignition key to "Lights ON" and the ATV immediately picked up as though it really was in HIGH gear. Switching the ignition back to "ON" was like down shifting into LOW gear. When I came to a stop and switched from LIGHTS on to just ON the ATV completely died. After a 30 minute ride you would think it would start again but I had to jump it again to get it to start. Same issues with the ignition having to be pointed to Lights for it to run decently. Then just as I got back to home base the display showed VOLT. It acts like it's something in the ignition but not sure how that's related to the gears. I put a gas cleaner in the tank since it's been sitting but it really doesn't seem like a bad gas issue that I thought it was at first. I checked the IGN fuse but it seems fine, replaced it with the extra fuse but no joy. Anyone have any ideas?? Thanks in advanced for any help. It's much appreciated.
Edited by TSWIII
spelling
  • Solution
Sounds like a voltage related issue. First thing I would test the battery. If the battery is bad you might be getting too much voltage and that will cause the display to blank out, turning on your lights puts a load on the system and would bring the voltage back down to normal level.
Mike
    • By Tinkeringreg
    • By kaidella
    • By jhamrick75
