I have a Timberwolf 250 that will only shift into reverse when it is in gear. It will not shift if in neutral. Has anyone had the same issue and if so how did you fix it?
Can you provide more information? Because this doesn't make sense. If you shift it to neutral then it should stay in neutral. If you want it in reverse then you have to shift it into reverse.
Check all the shift levers for operation and proper movement, grease joint if required. Check the oil level in the transmission if you have a dipstick or the means to do so.
The more information you provide the better!
There is a separate reverse lever. If the quad is in neutral the reverse lever will not move but if you change to 1st gear, then the reverse lever will move and allow you to change into reverse. Of course you need to simultaneously be pressing the rear brake pedal.
Now i understand. Sounds like something is out of adjustment. Usually they have safeties in place. Check to see if any of the linkages are loose or bolts that have come off from vibration or broken. On a two lever system, the safeties prevent the operator to shift into reverse if you're going forward without going through neutral or stopping and so on.
If you are courageous to attempt to fix it yourself, one thing I'd recommend you do is take a lot of pictures... almost for every step that you take or task you perform! I promise this comes in handy. If you share more photos, I'm sure we can resolve it together :)
Let me know what you find!
My Bear Tracker 250 requires that it be in first gear before shifting into reverse. It is designed that way and talks about it in the owner manual. I suspect that your Timber Wolf uses the same transmission in which case there is no problem . See below.
From Owners Manual
Drive select lever operation and reverse driving
CAUTION:Before shifting, stop the machine and re-turn the throttle lever to its closed posi-tion. Otherwise the transmission may bedamaged.NOTE:
When shifting into reverse, the transmissionmust be in first gear.
1. Bring the machine to a complete stopand return the throttle lever to the closedposition
.2. Apply the rear brake pedal.
3. Shift the transmission into first gear.
4. While pulling the lock release button,move the drive select lever toward therear until it completely stops
Thank you for this info. It just seemed weird as my other three Yamaha ATVs all need to be in Neutral before engaging reverse. I am sure that it is the exact same transmission
    • By Tim Keiper
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By Mhatayas
    • By Dumass
    • By fwsamm
