    • By Joeguy
      I been working on this thing for like 2 months now and it will not run right, is very smokey, and has a pretty loud tap that i think is in the bottom end. Not sure how much the parts are but i will put the time into it if they are pretty cheap. Im not very experienced but going off how the plug looks and the oil on top of the piston i am getting a whole lot of oil coming in from somewhere, not sure if it can come from the valves or if the rings are just shot, my cheap scope cant really see the walls of the cylinder too well.
      20241009_123850.mp4
    • By Ulfthednar
      Got others in the works.
      Been years since I really played with editing software and content creation. ATV+Gopro+Davinci.
      https://youtu.be/-JV-xEq9uW8
    • By Werewolf
      Oil is getting in the air box from crankcase vent tube, I put the two hoses that go to the air box together then something started to smoke on the front of the engine. There is a filter? In the line I blew that out.
    • By beast6228
      So the other day I picked up a Lakota 300, it's going to be a new project for a bit, the engine is super clean and so is the frame...luckily the VIN was intact.  However, it is the missing the air box (the one that holds the filter) but it does have the air chamber that goes to the carb.  These air boxes seem to be pretty pricey, so my question is has anyone had any luck running a pod filter on theirs and if so, what kind of jets are you running? The carb on this one is a Keihin CVK, I have yet to pull it off and inspect it.
