  • Admin changed the title to 2005 Yamaha Kodiak 450 noise from clutch
It's likely that the one way bearing that's part of the centrifugal clutch has failed. To check it out the cvt clutches have to be removed first.
There is a cover in behind them that gets removed to access the cf clutch system (that runs in engine oil btw).
What i would do is either pull the cover and pull the belt off of it and run it just to make sure that the noise is actually coming from the clutch itself. If the noise is still there id pull the clutch and check out the rollers in it.
And no sir theres not a special tool thats needed to remove that clutch its just a 22mm socket and then it pulls right off.
    • By Panupong Pradchaphet
