IMG_0309.thumb.jpeg.7390541fe54e204ef8e4f2966067c4d6.jpeg19 miles, 1.7 hours. Gas gauge reads full (WTF???).
 Lunch stop where I found some shade.IMG_0306.thumb.jpeg.aab9bc88ef58d9abafbae34edb962ea4.jpeg
  • 2 years later...
    • By Gunny
      Hope you enjoy the video ....
    • By JohnnyB
      Greetings,
      Have a 88 LT80 that been sitting for a couple years. Bought a new piston, cylinder and head. Installed these, rolled it over and it quickly locks up.  Took carb apart. It was full of what appears to be 2 cycle oil. Cleaned it, but keeps locking up and 2 cycle oil continues to seap from exhaust port.  When i installed new cylinder, I noticed crankcase was full of oil.  I'm now wondering if that oil is what's getting sucked up into cylinder.  Should there be no oil in crankcase?  If that the case, how is crank and rod lubricated?  Sorry, never worked on a 2 stroke. Thanks!
    • By McG75
      Sorry I suck at these forums so if you see this submitted under update status, my bad. Anyhow this is a new shock for a 96 Yamaha Kodiak 400 4x4 it fits my 96 Yamaha Timberwolf 250 4x4 perfectly. Little narrower are the bottom than the original but everything else is perfect. I extended it to almost a half in from full extension because I’m pushing 350 pounds.  It rides and hold me well. So if any of y'allRace driven shock. have been looking for one and didn’t want to do the research here it is.
    • By Clydaho
      Any other ideas?
      Thanks for any help,
      Clyde
      I just bought two 2002 Suzuki LT80K. Do I need to mix the gas or use straight unleaded?
