Anyone ever use or have any experience with aftermarket carbs, specifically one for the 500 Vinsons? Just ordered one off Amazon. Gonna give it a try. 47.00 bucks vs 600.00+ for OEM. Any thoughts or previous experiences? thanks, Fireslayer.
Not much experience but what I have bought have always needed retuning, sometimes quite a bit, and even if the carby was being sold for the very specific model quad.
I suspect though that even if you bought a carby off the manufacturer, it might be a compromised tune made to fit a bike in any market, and probably needing tuning for your fuel and altitude etc.
If it doesn't run good, fit your old jets and needle and everything if it can be done, if the new carb is the same make as the old.
I posted a video of a guy on u tube installing one on a Vinson, his seemed to work out well, but I haven't had good luck with them, I am in the process of going back to OEM on all my bikes that I bought used with Aftermarket carbs on them. Hope yours is good.
    • By Sportsman500guy
    • By qcm413
      Hi,
      thank in advance
    • By marcosphoto
      Hi folks, a little disparity brought me to this forum.  To set the stage, I'm a 35 auto tech in the industry 37 years now.  Licensed motorcycle tech also, 20+ years.  I race superbike and motocross.  Always done most of my own standard work (outside of specific race machine works) including building my own race bike engines.  Now that skills are out of the way, onwards and upwards.
      Helping a neighbor with his old quest 500, right front axle seal leak.  Well, looks like everything else - right?  Wrong!  Initially I noticed the CV joint was lacking large lands to place prybars on to pop it out, rather a thin shield like ring very close to the diff seal.  Knowing the ring appeared quite delicate, I only pried gently and the CV popped out.  However this is where things get weird.  Came out only around 7-9mm then hung up again, felt like the clip was catching inside the diff.  So spun and pulled, spun and pulled until I was blue in the face but no success getting it out.  Also while it was out, I could see that the delicate ring around the outer circumference of the joint was actually the sealing surface where the seal contacts, instead of the norm where the seal rubs inside the diff much deeper and stays cleaner.  I've never seen a joint like this, also the service manuals photos which apply to 650 also reflected a standard joint I am accustomed to rather than this one I was fighting with.  Rather than break something in the diff, I decided to stop while I was ahead and reassemble the machine before something broke.  (The joint would pop in and out of place easy enough, just wouldn't slide out further than 7-9mm).  While the joint was a little out and sealing surface exposed, I cleaned the seal and sealing surfaces clean as possible before putting back together.  Seems to be holding for now, but eventually I'm sure the leak will come back.  Any thoughts as to why that CV joint just refused to come all the way out?
    • By waybel
      Picked up this old 2000 polaris sportsman 500 and the speedometer is dead .Tried the bypass to get the awd drive to work but no luck.I grounded the 2 brown wires going to the hubs .Didn't work.The AWD light does not come on and there is no power on the grey wires going to the hubs .I even tried connecting the 2 brown wires at the speedometer plug in .There is 12 volts on the red with white stripe connected to brown at the speedometer plug in .Does the speedometer need to be plugged back in for this to work.Could it be the switch or a burned AWD bulb ?
