Hello,
Picked up what i thought was a 1997 KQ 300, it is missing all the plastic body fenders and the head light plastics.
Checked the VIN with one of the decoders from this forum and it said my quad was actually a 2002 LTF 300 F
which is fine, just wondering what changes were made from 1997 to 2002, Some service manuals list 1998 to 2002 as the same range/model.
I may check engine number as well to confirm engine year and model
I need correct identification for parts ordering etc.
I noticed some changes from the 1997 to 2000s models with the rear wheel driveshafts.
My rear shafts have an inner joint rubber cover (not sure if they are CVs or UJs), then appear to go to wheel hub without a 2nd flexible joint,
in other words it is most likely rear wheel drives are a single CV joint.
earlier models appear to be 2 UJs, am i correct here ?
Have ordered a cheapo CD service manual that hopefully should clear this up
regards
OZ
tried FAX VIN again 2002 LT-F300, nothing after the 300, eg F,K etc
possibly not much difference but i am still curious
just tried above parts lookup, excellent better than what i have been using, looks like the F/K after 300 is more for options , eg color, dual headlight etc
and looks like rear wheel drives are a single UJ with a boot over, im happy with tthat
OZ
There are probably hundreds of differences Oz. They change the general model every few years, but in all makes, and any model range, there will be heaps of parts differences. They change the carby specs(jets and needles for instance), just about every year, even though they are the same basic model of carby. They change stators and electrical systems a lot too. Gears and shafts change, sometimes because it's a superseded part design, and sometimes to give different ratios in different years.
Most of the service manuals cover a lot of years. They have all the stuff common to every model in the front, then at the end they list what was different for different years.
Keep posting till you've got permission to download a manual. Possibly download a couple. It's quite common once a bike's a few years old for things to have been changed, sometimes with a later part, like a suspension arm for instance. You need to read the manual and get to know the bike to be sure what you've got.
In some respects the X and Y are the same, and mostly the K is different.
thanks Mech, i agree but drum brakes versus disc brakes ? pretty weird option.
I needed a speedo assy for my 2002, got a 1997 version coming looks exactly the same but one connector is different.
Can deal with electrics better as I am an Aircraft Electrician, but buying the wrong suspension, drive train or brake parts would be annoying.
At least here in Australia I am finding a good supply of 2nd hand Suzuki parts from wreckers, gumtree (like Craigs list) etc at very reasonable prices.
Not to mention oil filter $9, air filter $27 and non OEM electrical parts
OZ
Yup, little things like the different wiring on an identical looking speedo is usual. It's the same with cars. Mostly the other parts will fit, if we swap all the other parts that go with it, such as changing one gear needing a new shaft for it to fit on, and then another gear on the other shaft..haha.
Bastards !
    • By Rich1028
      I Crashed My Quad
      Below are Three Videos.
      5 broken Ribs
      1 Punctured Lung
      1 Broken Collar Bone
    • By beast6228
      View File 1986-2006 Kawasaki Bayou 300 service manual
      This service manual is for a 1986-2006 Kawasaki Bayou 300.
      Adding to downloads library.
      Submitter Ajmboy Submitted 05/11/2018 Category Kawasaki ATV
    • By oxidized_black
      View File 1988-2002 Kawasaki Bayou 220 service manual
      Also available on eManualOnline
      The Kawasaki Bayou 220 is one of the most common all-terrain vehicles on off-road trails that is geared toward novice riders and families. It’s also one of the smallest and most inexpensive ATVs on the market, with a retail price under $3,500, as of 2010. The Bayou 220 is Kawasaki’s only ATV of its size. The 220’s sibling is the larger Bayou 250 equipped with a 228cc engine.
      Engine
      The Bayou 220’s engine is a 215cc, four-stroke, shaft-driven, air-cooled model. Its bore measures 2.6 inches and the stroke is 2.4 inches. It features a relatively high 9.3:1 compression ratio with fuel delivered through a Mikuni VM24SS carburetor. The electronic ignition is Kawasaki’s DC-CDI. It also features a recoil backup as a starting system. The clutch is an automatic wet multidisc model with power delivered to the wheels via a five-speed transmission, according to ATV Source.
      Chassis
      The steel frame supports a front suspension with single A-arms and twin shock absorbers, with the rear suspension a Quad-Link system with two shocks. Front wheel travel is 4.5 inches, while the rear wheel travel measures at 4.9 inches. Front and rear brakes are drums.
      Size
      The front tire size is AT21X8-9 with the rear tires measuring AT22X10-10. The ATV’s wheelbase is 43.9 inches, with an overall length of 68.7 inches. Ground clearance is 6.1 inches with the seat height measuring 28.7 inches. It weighs 403 lbs. and can tow up to 450 lbs. Its fuel tank can carry 2.6 gallons.
      Basics
      The Kawasaki Bayou 220 is not the fastest ATV on the market, but one reason the Bayou 220 has kept its price low is the lack of amenities. It features a brake light and dual headlamps with high/low beam. There is an auxiliary lighting terminal inside the front cover of the ATV and electrical accessory terminals under the seat. The instrument cluster atop the fuel tank features a fuel gauge, but not much else. There are no speedometer, odometer, hourmeter, tripmeter, high-beam indication or high-temperature light. It does have a reverse/neutral indicator light. The Bayou comes in two colors: hunter green and firecracker red.
      Features
      The front A-arm, twin shock and rear Quad-Link twin-shock suspension system is not a true fully independent system, but it allows for a comfortable ride over rough terrain without employing a complex and expensive, fully independent suspension system. The ATV features front and rear steel cargo racks. The ATV is rider-friendly with a limited adjustable throttle to help novices practice their riding skills without twisting the throttle too far and losing control of the vehicle.
      Submitter oxidized_black Submitted 12/14/2016 Category Kawasaki ATV
