The steering column on my Ranger will not stay stationary. The entire column moves up and down as it is being driven. It has a strut attached to the column for adjusting the steering wheel position and moves also. Any ideas on what is wrong and how to fix it
I'm not familiar with that but it's pretty common for the steering column to go through a couple of half round clamps that hold it to the frame and that it turns in. Then down the bottom of the shaft there's often a plate of some sort held on with a nut. I'd check the two half round clamps are tight and have their rubber bushes in them, and that the plate at the bottom's still done up tight. You might have to pull the bodywork off to get a good look at the upper clamp, but the bottom ones are normally pretty easy to see.
Get a manual and have a look, or look at the parts online.
    • By dalton7545
    • By motox88
    • By heath
    • By mga
      My 2000 big bear 400 4x4 has 26x10x12 tires in front and 26x12x12 in the rears. Trying to find replacement tires those sizes are hard to find, or, when i do, they cost a lot more than i want to spend.
      But, there's a lot of 25" tires out there the same size, just 25" and not 26". If i got the 25" it should not make a difference....right?
    • By hporter1208
      Okay, so I have a 2002 Rubicon 500…bought it last year and it sat for several months until I put a new rear axle in, FINALLY got that done and was super excited to finally have my wheeler going, just to notice a strong gas odor. Popped the seat off and sure enough, pouring gas from the carb overflow. Fast forward a few more weeks and get the new carb and get it in, no leak! Yay. Except now I have no spark. 😒 I’ve tried another plug and checked and am getting no power to the coil pack. I’ve read and read and mostly what I’ve found is ECU, which is fine…but I like to exhaust all avenues before buying the more expensive parts just because I don’t wanna spend the money and it have ended up being something simple that I overlooked because I was trying to rush. 😂 I don’t know if it’s relevant, but I read on another post that someone had similar issues with theirs and it was the sensor on the side of the carb, just a thought since this literally happened after I put the new carb on. It also displays “- -“ on the display screen where it should show the gear position.
