Gates are normally pretty reliable, and can be purchased without the dealers markup.
Look up gates belts, then the "automotive" link top right, then choose recreational vehicles and follow the selection process.
Edited by Mech
    • By qcm413
      Hi,
      thank in advance
    • By Coyote251
    • By cameronokeefe6
      I have owned my 84 Honda 200m for years now and I am wanting to see what i could do to upgrade horsepower , speed , performance , power etc and do it safely and not cause future harm to the engine.
      I was thinking on getting a 200x piston, will this work and give a good power increase ?  I have heard people have done this in the past and it works great. and i was also thinking on a 200x cam , will the 200x cam fit in this engine and make a difference also does it require the upgrading of any other parts and will i have to run 91 octane instead of 87 ? has anybody run this setup before and got good results ?
      I was also gonna go with a 200x carb but not sure if i have to buy an intake to hook it up or will it just bolt onto the 200m intake and fit fine ?
      If anyone has any suggestions and advice on what i could do it would be greatly appreciated ! thanks in advance.
    • By Gordo7799
      I am looking to replace the Maxxis AT 25x8-12 tires on my Yamaha Grizzly 700 and put on snows.  Going bigger to 27" and wider to 9" or 10" is probably a good idea, yes????? I've heard that Maxxis Zillas are good.
      I just want to use the quad on the trail to get into the lake and then go ice fishing.
      Appreciate any and all advice.
      Thank you!
