9 pin kill switch
By Atomusthenes
By TravisM
2001 bayou 220 KLF220A
I'm at a loss here. Thanks.
By mans
Were is the neutral safety switch on 03' Kodiak 400 4x4 . How xan i check it to see if it's good for a no neutral light no power to machine. Ty
By Frank Angerano
I’m looking for any member that may be familiar with the neutral safety switch on this bike.
I picked up a bayou 220 that I found sitting in a shed. Nice looking bike the guy said it would not start one day and put it away and never touched it again.
So it turns out the neutral safety switch is bad. I jumped it out and the bike fired up and runs good.
I’m more then capable of the work in changing it but this thing is buried pretty good. I’m curious if anyone has done the switch replacement before?
I attached some pics to see.
picture 1 is the side view you can see the green and red wires going into the cover.
Pic 2 shows looking down on the drive shaft coming out of that cover. That is not a simple cover you just pull off.
Im wondering how deep and how much sh** has to come off like the drive shaft etc for this switch to be replaced.
So if any of the QC members have done this switch I’m looking for any input with regard to changing it.
Thanks.
