Have a look at the service manuals and if the one manual does both years then the two bikes will be very similar, but parts do always change as they make small improvements and modifications to cure faults that come to light.
The best way to check if parts will interchange, especially without having to change several parts together, (like changing a gear, needing the later model gear shaft to suit it), is to find an online parts place that lets you see what other model the part you look up fits. Often once you select a part online, they will tell you what other models they fit and the other part number(if there is one) if it's for the other model.
    • By Thumpinhard25
    • By fwsamm
