That's a strange one !
What sort of chain adjuster does it have, a manual adjustment or an automatic one ? Is it in good order ? If it's an automatic sort, is the ratchet in good condition..
Does it do it when it's running or as you rotate the motor by hand ? Is it perhaps trying to jump when the motor either backfires or as it comes up against compression as the motor's coming to a stop ? Some cam chain tensioners don't like the engine being turned backwards, or backfiring. The tensioners are only designed to take the slack out of the chain on the loose side, and don't always handle the load of being on the tight side if the motor's being turned backwards or backfiring.
Are the sprockets in good condition ?
Does the top and bottom sprocket look to be in line if viewed from above.. could the chain be trying to creep sideways and come off the sprocket ?
Is the chain the right pitch for the sprockets ? Do the links sit nicely on every tooth they contact ?
Are the cam bearings good ?
Edited by Mech
    • By Atomusthenes
    • By carkivey3
    • By beast6228
      However, last night I was looking at the service manual and noticed that it mentioned that this atv has a crankcase breather tube as well. Mine does not have one, so I looked at Partzilla and looked at the parts diagram and sure enough, it's definitely supposed to have one. The problem however is, the service manual does not show how it hooks up and the parts diagram only shows the exploded view of the assembly. I just find that kind of strange, nowhere in the manual does it show how it connects. Does it have it connector, attach to a nipple? It just doesn't say and it bothers me that there is a hole there without anything attached to it.  If anyone has a Bayou 300 or Lakota 300 with an intact breather vent system and could possibly take some clear photos of it or know how it connects I would be very grateful. I have searched high and low and cannot find any information on it.
