New to the quads my neighbor just gave me an old Suzuki quadrunner 230. It has been sitting on his trailer in the back 40 for 7 years since it last ran so I figured it would be a good winter project.  Not sure of the year I believe late 80’s
I am sure I will have lots of questions but for now just searching the forums for info.
  • Admin changed the title to New to quads was given a Suzuki quadrunner 230
I got the quart started last night after replacing the card, fuel tank clean and oil change.
new to this machine does it have just oil in crank case (I only found the one drain plug) or is there also gear box oil .
do you know the exact year? If you can grab the serial number (should be on the frame (back left upright) you can type it into the decoder and find out the year. Then you can go look it up on Suzuki Parts House and see some diagrams.
I am not familiar with that bike but I don't think it is 4x4. If it is the front pumpkin would have its own drain plug and a different type of fluid needed. The crank case oil should be working as your gear oil as well on the rear end. That is the way all of my old (90 models) Suzuki Quad Runners and my new King Quad (2020) are set up. Just make sure that you use a proper ATV oil. Don't use regular automotive oil, the ATV oil as additives in it to help with extra job functions.
Thanks, I found the serial number and it is a 91. Are these things 2 stroke or just straight gas ? I just rebuilt all the brakes and took it for a short run down the road to make sure it shifted ok . It runs not too bad, I did notice that it seemed hot when I came back in cyl head temp was around 300f and exhaust was 250 or so. Gear box was around 100 not sure if this is normal ?
If it is a four stroke engine it runs on straight gas.  I have a Quad runner 250 and it is a similar engine.  It only takes oil in the crankcase from what I know.  My engine always ran a little hot but 300 F does sound like a lot though.  I would make sure the mixture is right, if it is running to lean (not enough fuel) it will get hot because fuel cools the engine.  There should be a mixture screw on the carburetor turn it out a 1/4 turn and see if the temperature decreases.
The idle mixture screw only effects the idle running and won't make it run hot... A lean high speed mixture will though.
And, not that it's really important, but for your information CalebM, the reason they run hot if lean isn't because fuel cools the motor, but because a lean mixture burns slowly and the flame has more time to heat the cylinder. The same's true of a retarded spark, the late ignition point means the fuel's still burning as the piston gets a long way down the cylinder and there is more opportunity for the heat to soak into the cylinder. It works the same way in a diesel if pushed.. the fuel being injected for longer means there's more time and area for the heat to soak in, or, what's normally noticed, the exhaust temp goes right up real fast.
Edited by Mech
Ok, yeah sorry I’m still new to some of this stuff I was told by somebody if it runs to lean on fuel sometimes it will burn up the motor.  I always run engines a bit richer just in case.
Nothing to be sorry about Caleb, we all have to keep on learning, me included, and I'm ancient !
Motors do run hot if they are too lean, but it's really only the main mixtures that will do it... or the ignition timing being too retarded.
  • 4 months later...
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By Frank Angerano
    • By Tinkeringreg
