SLC kit
By Sportsman500guy
By Winnem
Hello.
I've bought myself a Iron Baltic electric hydraulic plow lifter for my TGB, with a matching mounting kit. It was supposed to fit directly on my ATV. But I'm really not happy with the result. Had to cut off some of the cover under the atv, and still the angle didn't seem to be right in order to fasten the adapter on top. Also it touches the bumper and makes ugly marks.
Is there anyone here with experience, or know a good solution on this?
By DonB
Had fire start in muffler due to failing fuel pump &/or fuel pressure regulator. Must I spend the $750+ for a new assembly from Arctic Cat?!? Here's what I've tried so far.
Replaced fuel pump & regulator - both from Quantum. PSI is 60 rather than the 42 the dealer advises it should be, so problem persists. I've now twice replaced the Quantum regulator & discussed w/ Quantum. They advise that they don't have an alternative regulator that would bring PSI down to 42. I've tried several in-line, adjustable pressure regulators but they either didn't work or I couldn't get a constant pressure from them. FYI, I've only tried the adjustable regulators for Fuel Injected engines however, it seems that they require vacuum to function properly. When I can temporarily get the PSI right, everything works great. Anyone else ever dealt with this problem, and, if so how did you fix it? Perhaps I should adapt the fuel system to include a gas tank return line?
Any insights are greatly appreciated, Don
By ATVNetwork
he fifth round of the 2024 ATV Motocross National Championship Series, an AMA National Championship, took place at High Point Raceway View the full article
By ATVNetwork
he fifth round of the 2024 ATV Motocross National Championship Series, an AMA National Championship, took place at High Point RacewayView the full article
