Otter9099 Posted September 20, 2021 #1 Posted September 20, 2021 What battery type is best wet cell, agm or lithium? Who makes the most reliable battery for atv's? I need to replace a battery on my qtv. It had a wet cell lead acid. What doe you recomend for a replacement battery that is not a fortune and that is reliable? Quote
Okiechoctaw Posted September 22, 2021 #2 Posted September 22, 2021 Agm are what we used in the military there pretty rugged and God forbid if you flip you won't have to worry about it spilling. I couldn't tell you anything on lithium Quote
Solution davefrombc Posted September 22, 2021 Solution #3 Posted September 22, 2021 For ATVs and snowmobiles the AGM has the advantage in cold weather. They are also a lot less expensive. Lithium shines in solar applications and where very deep cycling is wanted without service life suffering as badly , and of they have a weight advantage when used in a battery bank in a motorhome. For motorcycles, ATVs and Snowmobiles where you want cold weather starting and charging far more than need of reserve capacity, go with AGM or SLA. They're rugged, better in the cold and are far less expensive than Lithium 1 Quote
Autismdad956 Posted September 23, 2021 #4 Posted September 23, 2021 Ive never had any problem with agm. Quote
KansasKodiak Posted September 27, 2021 #5 Posted September 27, 2021 I literally just bought a new AGM battery two weeks ago and it's worked out great. Everything I've read about them talks about reliability and how you'll get years of use out of them. I know for my other small equipment around my farm I use small solar panel chargers (8 watts) to direct charge batteries during cold months or when stuff has to sit a long time. Those panels are cheap and easy to use and seem to do the trick so far for years. Quote
Avery Johnson Posted October 3, 2021 #6 Posted October 3, 2021 Hell, I have to replace mine every year. It sets alot. 2007 Suzuki King Quad 700. Quote
davefrombc Posted October 3, 2021 #7 Posted October 3, 2021 3 hours ago, Avery Johnson said: Hell, I have to replace mine every year. It sets alot. 2007 Suzuki King Quad 700. When your quad sits a lot , especially the new electronic ignition, computer controlled ones they should be kept on a battery maintainer. The small trickle used by the electronics even when the ignition is off will drain the battery. SLA and AGM batteries also always have a bit of self discharge so the combination of the electronics and self discharge means they must be kept up topped up. They do not like to be deep discharged and quickly lose capacity if they are .. Totally flatten either type and you are pretty much guaranteed the battery is toast.. A small maintainer is a lot cheaper than a battery and will eliminate the buying of a new battery every year. I have one on my truck, another on my quad and a third on my riding lawnmower. 1 1 Quote
KansasKodiak Posted October 4, 2021 #8 Posted October 4, 2021 You are on the money with small rechargers. First year I owned both my lawn tractor and HD Road King I replaced the batteries. The winter drained the batteries charge down below it's capacity to recover. I learned my lesson on that and now keep all batteries on some type of trickle charging system; whether it's solar or electric. It's definitely cheaper in the long term since most batteries that are taken care of will last around five years. 1 Quote
Curtis Underwood Posted October 5, 2021 #9 Posted October 5, 2021 On 10/3/2021 at 2:45 PM, davefrombc said: When your quad sits a lot , especially the new electronic ignition, computer controlled ones they should be kept on a battery maintainer. The small trickle used by the electronics even when the ignition is off will drain the battery. SLA and AGM batteries also always have a bit of self discharge so the combination of the electronics and self discharge means they must be kept up topped up. They do not like to be deep discharged and quickly lose capacity if they are .. Totally flatten either type and you are pretty much guaranteed the battery is toast.. A small maintainer is a lot cheaper than a battery and will eliminate the buying of a new battery every year. I have one on my truck, another on my quad and a third on my riding lawnmower. 47 minutes ago, KansasKodiak said: You are on the money with small rechargers. First year I owned both my lawn tractor and HD Road King I replaced the batteries. The winter drained the batteries charge down below it's capacity to recover. I learned my lesson on that and now keep all batteries on some type of trickle charging system; whether it's solar or electric. It's definitely cheaper in the long term since most batteries that are taken care of will last around five years. You both are correct. Here is something you might consider. They make a charger that will recover a AGM that has been completely discharged and set up for a while. These chargers have a battery reconditioner in them. What this does is to put out a low frequency pulse that takes about 48 hrs to break up the solidification that happens when these batteries set up and completely drain. But I have found on a good battery they will tend to try to recondition them if the battery voltage is below 11.8 volts and it will not charge it until the battery recovers to above 12 volts.. If you use your lights and say your winch it will drain the battery below this point. So I have about 4 chargers lol one I use to recharge a low battery, couple I use for as a maintainer and this reconditioner that will recover some of the batteries but not all of them. It has recovered 3 out 4 I have used it on. The fourth one I think may have had a dead cell(meaning the plates were worn out from use) and it was 5 years old and the others were like 3 years old and less. Quote
fox2boost Posted October 13, 2021 #10 Posted October 13, 2021 ive had goodluck with the yuasa brand batteries Quote
KansasKodiak Posted October 14, 2021 #11 Posted October 14, 2021 I never knew you could recover a dead battery. I'm going to look into buying one. Can you recommend a brand? Quote
Curtis Underwood Posted October 14, 2021 #12 Posted October 14, 2021 I bought a Everstart Max from Walmart. Think it was 39$. It does the job but like I said if the battery gets too low on voltage, instead of recharging it will try to recover it. What I do when this happens and I know the battery is ok I use my old charger to fully charge it. Then I will let battery set for a day then put the conditioner on it and if something is wrong then I let the reconditioner stay on it for 24 hrs then recharge and test it again. If the battery is solidified it will lose charge pretty fast just sitting on a table. Quote
JustRandy Posted October 18, 2021 #13 Posted October 18, 2021 An AGM left me stranded on top of a mountain and I swore I'd never use another. I had to walk 2 hours back to camp to retrieve a lead acid battery. Lead acid is better except for the fact that all the bouncing around on an ATV makes it impossible to keep the acid in it which corrodes any metal on the ATV and destroys the battery. I'm currently using gel batteries which are somewhere between AGM and lead acid. 1 Quote
davefrombc Posted October 19, 2021 #14 Posted October 19, 2021 Except for Lithium batteries they're all lead / acid. Flooded batteries are the worst and cheapest. A very poor choice for an atv that sees lots of off camber travel, bounces and shaking. The leak acid because of it and wreak hell on everything that acid touches .. SLA ( Sealed Lead Acid ) batteries are just that . They are sealed and vented; built better to withstand all the shaking better than the cheaper batteries that can leak so easily. They still must be mounted upright though. AGM ( Absorbent glass mat ) batteries have the electrolyte absorbed in a glass mat. There is no free acid in it to spill so they can be mounted in any position and are the most resistant to damage from the rough environment found in ATV use. They all must be kept charged by a maintainer when not in use as they all have some level of self discharge and too deep a discharge can reduce their capacity or destroy them. For price and performance, in an ATV the SLA is the best choice of the three. Quote
RamzV Posted October 30, 2021 #15 Posted October 30, 2021 My vote is for AGM , cheap enough to keep a few on hand Quote
