So, I have a 2000 lt-f250f quad, and my brother gave me a new +0.5 oversized piston that he bought for his King Quad (280cc), and never used. I'm wondering if I can bore my cylinder far enough to use this with my cylinder. or if I need to buy a 280 cylinder? another question I have is if I need to buy a 280 cylinder, would the crankcase hole where the cylinder sits down into, will be large enough to let the 280 cylinder fit, without opening that up?
Best bet would probably be to stick with parts for your specific machine, then if you want buy an oversized piston for the lt250 and have the cylinder bored to that.
I could be wrong, but I believe based on what I learned from JustRandy, the 300 piston would not work in your motor, even if you could bore the jug out to accommodate it, because the 300 uses a 17mm wrist pin and everything else (except the '89-90 LT250s) uses 16mm.
    • By Tim Keiper
    • By Rich1028
      I Crashed My Quad
      Below are Three Videos.
      5 broken Ribs
      1 Punctured Lung
      1 Broken Collar Bone
    • By Trent Finnessey
    • By Randomnumber73
