I purchased a Craftsman Outfitter 550 UTV from Tractor Supply a few months ago.  It is a good UTV, but getting support for them is a pain.
My current problem is the Turn signals and the Hazard lights.  There is power to the rocker switches on the dashboard, but no power is getting to the Flasher Relay.
Any ideas.  I found a copy of the wiring diagram on the internet, but it is worse to read the translating Chinese.
First item to check is always the fuse for that circuit. A volt meter with a continuity checker built in would make that easy to do, but they can be visually checked for a gap in the conductor inside the fuse body. Hope it's that because that's the easiest fix. I would also have a look at the wiring harness that is going to the flasher. Maybe a wire got pinched or chewed. Good luck!
k-bo
This is for an atv, but it might give you some ideas..  If this diagram seems similar to yours then I'd check the emergency flasher switch and the indicator switch works(with an ohm gauge), and that power was getting to the emergency lamp flasher. Then I'd suspect the flasher unit..
It's unlikely that both swiches have failed together, or that all the various bulbs have blown together, so it really looks like a lack of power supply to the flasher, or a failed flasher.
output.pdf
    • By leecon
    • By KSIM
    • By KSIM
    • By Eisaks777
