I have a leak on shifter shaft on my 2003 Lakota 300 sport.I have already changed a seal and still leaking while looking on a exploded blue print I see a metal bushing goes in then seal so I now have the bushing, can this bushing be replaced without taking cover off and where does it go ? I guess ill see when i go to fix it but any advice before hand would be much appreciated thanks in advance.Also if I take the cover off anything I should watch out for as far as anything that may come loose with cover off ?
    • By Mhatayas
    • By DPDISXR4Ti
      Thanks...
    • By beast6228
      View File 1986-2006 Kawasaki Bayou 300 service manual
      This service manual is for a 1986-2006 Kawasaki Bayou 300.
      Adding to downloads library.
      Submitter Ajmboy Submitted 05/11/2018 Category Kawasaki ATV
