I have a Polaris Magnum that is having issues. After returning to the farm after being away from knee surgery, I found my Magnum unwilling to start. I replaced the spark plug, no luck starting. Moved on to the ignition coil thinking that maybe that was an issue since it looked in rough shape. The 4 wheeler was out of gas so my thought was clogged fuel pump and/or carb gunked up. Both are clean so that isn't the problem. Now I am getting absolutely no spark when I try to start it. What else could be possible issues? CDI module, stator or solenoid issue? I really need this thing running, I use it to carry feed out to my birds so I don't have to carry feed.
Anyone have any ideas?
I made sure it was on early on. I'm beginning to think it might be the stator. That's not something I'm brave enough to deal with. Had to stop messing with because of the heat.
    • By Tinkeringreg
    • By oxidized_black
    • By Kawasakibayounospark
    • By neilroy87
