Best Looking
16 members have voted
  1. 1. Best Looking
    • Yamaha YFZ450
    • Honda 450R
    • Suzuki Quadracer 450
    • Polaris Outlaw 525IRS/S/450MXR
    • Can-Am DS450
    • Yamaha Raptor 700r/660
    • Yamaha Banshee
    • Other [If so State in a post]
    • By Werewolf
    • By Cobra_kai83
      The gas in the tank was bad so I drained it and put new fuel in. It still wouldn't run so I took the carb out and cleaned it. Re-installed the carb and now it will only start and run under full throttle. It also runs rough like this. The engine stops running once I back out to 1/4 throttle. What the heck is going on?
    • By Seriousbird
      Recently swapped a good top end with a bad drive output onto a engine with a bad top end but with a good drive output.
      Engine 1 (bad drive output), top end was perfect and always ran good for me.
      Engine 2 (good drive output), top end was toast but it has a output.
      I swapped engine 1's top end onto engine 2. Didn't take the rings off all i did was everything from the piston to the valve cover. Sleeve, cylinder, valve system, cam, whole top end. Now that engine 1 is on engine 2 it runs good. Doesn't burn any oil, SOMETIMES.. i went on a fairly decent ride without burning a drop of oil then at one point i noticed i was burning it like a steam train. Drove off a bit more and it was like nothing happened?? It all happened on flat land. Im not overfull on oil. Any suggestions? The rings were untouched and are in their original cylinder. They did come out of the cylinder at one point.
    • By Bdubb0227
      Hey guys, I'm new on here but I have a hell of a problem.  I traded for a 98 timberwolf 2x4 and it ran good but smoked.  So I decided to get piston and rings with new jug a and put everything together did the timing by the marks on the fly wheel and the cam gear and now all its is rolling over in the back fires extremely loud someone please help
    • By subetha73
      Up until the other day, I could electric start in any gear, now it will only start in neutral.
      Thanks for any help:)
