SO I'm riding along, on a paved road, going like 25-30mph and outta nowehere, she shuts down and has good resistance upon "coasting" still in gear (Hi). I come to a a stop and try the starter: Absolutely nothing. Shes locked up tighter than a drum. The ODD part is, after looking it over visually, I see the top of the motor transmission/cfrank area has oil. It must have come from the seam between the case halves.
Does this scenario exist, or am I the one in a zillion?
Or coming from the airbox and dripping down. Hard to say without seeing it. I think you have a couple issues going on, the engine seizing and the oil leak but I dont think they are necessarily connected. Might want to check and see if you have any leaking boots or seals that could have leaned out the fuel mixture and locked up your piston. Could also be filled too full of oil and oil is dripping from your airbox down on to the engine and also making its way to the intake and hydrolocking the piston
    • By Sportsman500guy
    • By dalton7545
      Just aquired this Honda 4514. I had heard of them and seen them but had never really looked at one. Amazing machine from the 90s.
      It has a 14 HP inline 2 cylinder engine. A cute little fan like the old school cars had and a little radiator. It has a timing belt on the back of the engine running the cam and a water pump. Just like a miniature car engine with  electronic clutches to turn blades on and off. Pretty hight tech for the 90s not a small thing and built like a tank weighs in at 600 pds hydrostatic trans. I have found out that almost anything you have to do to it the engine has to come out starter timing belt water pump. Very expensive parts i think most got junked for that reason, i did find out they were built by John Deere except for the honda engine.
      Does anyone here have any expierience with these.
