So my oldest strolls up to the garage the other day with this fine specimen of day's past, a 96 or so Quadrunner.  Doesn't run, but it's complete...and free.  Had to soak the carb for 3 days in lacquer thinner and replace the fuel pump, but yesterday it ran down the road and back.  Always fun to ride one that's been sitting for years.
Here it is after cleaning the carb, gas tank, and replacing the fuel pump.  Next up is what to do about tires.  The back two are dry rotted and won't hold air.  They are also 10" wheels so there's no good options for a replacement tire that aren't more than the thing is worth.  Thinking about drilling an extra set of 4x110 wheels I already have that aren't on anything.
Ended up trading this one as it sat for a 9mm.  Not a bad trade having only $50 in it.  As far as an ignition switch, I'm not sure.  Lots of Suzuki's had them, but that's about all I can remember in older stuff.  Newer Can Am's have a 3 way but that's a chipped key that requires an ECU.  I would bet something like the link below would work, but can't confirm since I don't have either available to check.
https://www.hqpowersports.com/p/ignition-key-switch-1987-1995-suzuki-lt-80s-lt-80-s-atv-new/
I have a 96 LT quadrunner 230 GE runs great love it i did a few tuneup things air filter oil filter amd change final gear gear oil doing back brakes ..Quad runs excellent  Also did new tires in rear ebay you can find lots of parts
    • By Gunny
      Hope you enjoy the video ....
    • By Dumass
    • By Trent Finnessey
    • By DPDISXR4Ti
      Thanks...
    • By jhamrick75
