Hey iv got a 2009 renegade 800x with no power at all no relays clicking no gages no nothing.
I look at all the obvious places and found nothing.
It was running and drove to where it currently sits and has been there for the winter.
Any advice would be greatly appreciated.
Sent from my SM-N986W using Tapatalk
Other than  repeating the obvious I can't offer  much more .
Start at the battery.  Make sure it is full  charged .Check for a blown  fuse or fusible link. Check the terminals and ground wire for  loose /  corrosion and then  follow the power forward to where it is first lost. Check   a wiring diagram to see what controls the power to that point, and so  on until you hit  on where the failure is .. There are service manuals for earlier Renegade 800 models in the downloads section that  may have the same wiring diagram  as your machine.
Never thought of looking for a manual I'll have to try and find one.
I did just figure it out there was a short on the kill switch so even with the switch off the machine thought the kill switch was on.
I uploaded the wiring diagram if you need it:
    • By jhamrick75
    • By qcm413
      Hi,
      thank in advance
    • By DaleJAM
      Covers the following models:
      1985   Scrambler Trail Boss
      1986   Scrambler
      1986   Trail Boss
      1986   Scrambler
      1986   Trail Boss
      1987   Trail Boss
      1987   Cyclone
      1987   Trail Boss 4x4
      1987   Trail Boss 4x4
      1987   Trail Boss 4x4
      1988   Trail Boss 2x4
      1988   Trail Boss 4x4
      1988   Trail Boss 250 RIES
      1989   Trail Boss
      1989   Trail Boss 2x4
      1989   Trail Boss 4x4
      1989   Big Boss 4x6
      1989   Big Boss 4x6
      1990   Trail Blazer
      1990   Trail Boss 250
      1990   Trail Boss 2x4
      1990   Trail Boss 2x4 350L
      1990   Trail Boss 4x4
      1990   Trail Boss 4x4 350L
      1990   Big Boss 4x6
      1991   Trail Blazer
      1991   Trail Boss 250
      1991   Trail Boss 2x4
      1991   Trail Boss 2x4 350L
      1991   Trail Boss 4x4
      1991   Trail Boss 4x4 350L
      1991   Big Boss 4x6
      1991   Big Boss 6x6
      1992   Trail Blazer
      1992   Trail Boss 250
      1992   Trail Boss 2x4
      1992   Trail Boss 2x4 350L
      1992   Trail Boss 4x4
      1992   Trail Boss 4x4 350L
      1992   Big Boss 4x6
      1992   Big Boss 6x6
      1993   2502x4
      1993   3502x4
      1993   2504x4
      1993   3504x4
      1993   Sportsman
      1993   2506x6
      1993   3506x6
      1993   Trail Boss
      1993   Trail Blazer
      1994   3002x4
      1994   4002x4
      1994   3004x4
      1994   4004x4
      1994   3006x6
      1994   4006x6
      1994   Trail Boss 2W
      1994   Trail Blazer 2W
      1994   Sportsman 4x4
      1994   Sport
      1995   3002x4
      1995   4002x4
      1995   3004x4
      1995   Xplorer4x4
      1995   4006x6
      1995   Trail Boss
      1995   Trail Blazer
      1995   Sportsman 4x4
      1995   Scrambler
      1995   Magnum 2x4
      1995   Magnum 4x4
      1995   Sport
