I have a 2014 CForce 500. The front differential will not engage when the 4WD button is activated. You can hear the relay click when the button is pressed but the 4x4 doesn't engage.
In order to get to the actuator it appears that the front differential has to be partially removed to access the bottom bolt on the actuator. Before I start disassembly, does anyone know of a source for the replacement parts?
  • Ajmboy changed the title to 2014 CForce 500 4X4 issues
    • By leecon
    • By fwsamm
    • By carkivey3
    • By KSIM
      View File CFMOTO CFORCE 1000 CF1000AU/CF1000ATR service manual
      cforce_1000_2018.pdf
      Submitter KSIM Submitted 03/08/2025 Category CFMOTO ATV
    • By KSIM
      View File CFMOTO CFORCE 520 CF500AU-7L/CF500AU-7S service manual
