Happy New Year everyone! I heard from my daughter that the 80's are coming back. Cindy Lauper performed in NYC last night, who would have thought...I say if that's the case, bring back the 70s!
New Year Party GIF by Omer Studios
    • By Chucksta
      So.. It has now become cranky about changing from "drive" to "reverse". Sometimes it's seamless as it's always been, other times it just goes "click, click....click, click " when going from reverse to forward, or from forward to reverse..  Then it gives up and just stops at neutral.  Only thing that seems to help is to give it a bit of a bump / wiggle with my own weight. Any ideas as to what to check? It's low miules / hours .. Dealership maintained..
    • By Vlaco
      Hi. I just joined the community. I have a sheep farm and use a Polaris 500HO, Polaris 700efi and a JD Gator 825i for different jobs around the farm. I do all the repairs myself so I am sometimes needing some advice and maybe I can be of some help to others as well.
    • By davefrombc
      COVID, record heat wave,  fires,  floods, deep freeze and more fires. Good riddance 2021.  Have a Safe and very  HAPPY NEW YEAR everyone.  May 2022  make up  for the trials  of the last 2
    • By DGBear
      This thing is stuck in reverse! 2021 Axis with less than 15 hours on it. I cranked it, let it idle for a few minutes and when I put it in reverse the engine died and it won't come out of reverse gear. Any help is appreciated.
    • By nblain
      Sorry, bit of newbie question on Honda TRX520
      Can anyone tell me if it is necessary to drain the engine oil to just remove the oil filter cover?
      I recently carried out an oil change and when checking afterwards, found oil leaking from around the oil filter cover (was torqued to 10Nm). I am going to get new O rings to be on the safe side, but was wondering how high the oil level in the engine sits relative to the pump filter and do I have to drain the oil?
      TIA
      Nigel
