Can't suggest any  dress up mods but you might consider adding an accessory  socket to it if it doesn't already have one.  Comes in handy to  run  a small 12v air compressor or other small  12v accessories .  All  you need is an aftermarket accessory socket , 15 amp inline fuse , some 14 gauge wire and connectors and   a hole saw or cutter to  bore the hole for the socket in the plastics.  Get a socket that  has the rubber cover to  keep the crud out when  it is not in use.
    • By Panupong Pradchaphet
