1994 Kawasaki Bayou 400 power loss
By zajavajunkie
Hello Folks
Have a Kawasaki Bayou 220, called the KLF 220 in my neck of the woods. I have had some fun getting to run nicely and eventually found a chap who sorted it all out for me. Something about 80-year-old bike specialists that make all the difference.
Anyrate now that she is running, I want to clean up or replace the spring suspension. so to my questions -
[1] has anyone changed/upgraded the spring suspension? if yes to what?
[2] The thought crossed my mind to split the spring system and change the actual springs for something firmer and give them some love while at it.. Has anyone split apart the springs, if so how does one go about separating the springs from the shafts?
Comments appreciated.
Hello from sunny South Africa
Royden
By lester
I picked up a 2000 Big Bear 400 4X4 that was sitting around that I know nothing about. It will not start. I do have a red light when in reverse. When I take it out of reverse, I do not get a green neutral light, and when I push the start button the red oil light comes on but there are no noises, nothing else happens. How do I test the neutral switch and/or bypass it to see if I can get it to at least crank? And does anyone have other suggestions for me to try?
By bob2007
By cavry
Thanks for any help
Cavry
By HoldenBoy
