Quadzilla 800 CFMOTO
By Eisaks777
hello, i have bpr bombaradier rally 200 2007 which has a lot of gasoline in the oil sump, it is 4 stroke. Has anybody had problem like this and which can be the cause and how to fix it. i rode it today at -2 degrees celcius if it helps.
By Snick
Bought the project a few weeks ago with weak and intermittent spark. I could smack the CDI box with a screwdriver and it would work fine for a few days. Now, the smack trick is not working and machine is running awful with the weak spark and will most often not fire enough to turn the engine over through combustion (cranks very good). I ordered the GY6 CDI to see if I can get it going again as these CDI boxes are way too expensive even used. battery is fully charged and charging very good.
Wondering if anyone knows how the GY6 (6-pin AC) CDI would wire to this machine. Attached is the electrical diagram. My confusion is with the green and orange wires sharing the 2-pin connector and the Blk/Red wire that runs to the magneto solo. How would I get AC power to the CDI through pin 1 on the GY6 when the CDI has two wires to the pickup-myabe just try one (orange then green) at a time?
^PINOUT:
5 6
2 4
1 3
By Ejwill
I put a new carb on my trx500fe which I have done before on other models, but this foreman was a real pain, takes forever to get to the carb. Anyway I got the new one installed . I also changed the choke cable while I had it this far. When I turned the gas back gas started running into the air filter box. I did have trouble with the choke cable, it didn’t seem long enough to run where the old one did and the elbow that came with the new carb had more of a 90 on the angle. It didn’t feel like it was binding but I don’t know if the valve was seated on the valve seat. The choke pushed in smooth but who knows what happened in side the valve body. I don’t know if this could be the problem or not I hadn’t run the it just turned the gas back on. Appreciate any help, hint, hint Mech and GW or anybody else. Deer season is over in a little over a week. My power chair won’t make it down those muddy roads. Thanks again.
By disturbedmike244
I have a 99 kodiak 400 4x4 that blows a fuse under the back left fender as soon as you attempt to put a new one in even with the key turned off. I'm having a hard time finding any wiring diagrams that show what this is for. And I'm trying not to have to tear into the wire harness. Any help would be appreciated.
