I have a 99 250 Quadrunner. Currently has no spark. It would run for 5 minutes, then shut off. After it cooled down about 20-30 minutes, it would start again. I ordered a new stator and found the old one was damaged (copper windings broken)  I installed the new stator, filled with oil and now it has no spark. Any assistance would be helpful
CDI? Obviously the stator feeds this, did you disturb the wiring? Check the wiring plugs ... pull them apart and spray with contact cleaner and reconnect. Also did you do the stator checks on the new one (even though it's new it could be broken or earthing)?
    • By Tinkeringreg
    • By Mhatayas
    • By Kawasakibayounospark
    • By carkivey3
