Hi all, I was gifted this Bayou but she's been sitting quite some time. It won't crank using the factory start button but when I jumper the starter solenoid it cranks but there is no spark. The key has power coming in on the white wire and when turned on supplies power to the brown wire coming out.
I guess I should start with testing the pickup? I heard I may be able to jumper the wires coming from the pickup with an LED bulb and it will flash? I noticed in the manual that it should have around 110 ohms resistance so I'll check that as well. One thing I noticed was that the starter circuit relay has power on one of the black wires with the key on- this doesn't seem normal as I'm assuming the black wires are grounds? I think one of them comes from the start switch, travels through the starter circuit relay and then grounds the starter relay?
Mine is a 1991 so it has the 7 wire CDI (ignitor) and a 2 yellow wire alternator ( as opposed to the later 3 wire type ) with another 2 wires for the source coils (black & red wires ). The pickup wires are blue and black I do believe. Any help appreciated and yes I will test the pickup ASAP.
I'm trying to understand how the system works and I don't understand what the yellow / red wire from the kill switch does- I assume it gets grounded when the kill switch is "on" and therefore grounds the CDI so it can't activate the ignition coil? I noticed in the diagram that that yellow / red wire looks like it may be grounded by the ignition key switch when in the "off" position?
I also don't have 12v power at any of the wires going into the CDI- doesn't the CDI need to be powered? I also read on this forum that someone used a GM HEI module in place of the factory CDI just to test it for spark- does anyone have any info on that?
I hope I'm not missing something simple!
Here is a link to the diagram for my bike (which was posted by another user): https://www.quadcrazy.com/atvforum/topic/13742-1988-bayou-220-lost-spark/?tab=comments#comment-101193
Any help appreciated!
2 minutes ago, Ajmboy said:
Neural switch possibly?
Thanks. That's possible but I did bypass the starter circuit relay (jumpered 2 black wires) and it made no difference. I'm going to get back at it in the next day or so and I'll report back my findings.
    • By Tinkeringreg
    • By Arizona
    • By Kawasakibayounospark
