Yeah I know its been a while since I've been on but, I've recently aquired a 2005 Polaris ATP 500. As ya'll well know I'm sure that these things are notorious for faulty ECMs and they are made of unobtanium. I got this one from my brother. I've unpotted the old ECM and tested the components and have concluded that they don't flow the board properly from the factory so that's why they crap out.  I've also done some research and found that if you take the harness and Stator and flywheel from a 2004 its basically a plug & play application and it eliminates the need for the ECM. Why the heck they put it in anyways is beyond me. I'm going to devise a way to make a plug & play adapter harness that eliminates the need for the ECM and restores the wheeler to use. Has anyone tried this before and had any luck? I've been trying to locate a wiring diagrams online so I can compare the 2004 to the 2005 but they're pretty hard to find.
Well I got the Polaris fired up yesterday. I was mapping out the wiring harness and found some corroded pins, typical. I also found that the grounding points on the frame were still painted and the terminals were corroded. I also happened to have another ECM that was the original one that was supposedly bad. After cleaning connections I plugged in the ECM to see if I could get any kind of life so I could map power out. Wouldn't you know it the dang thing powered up. I put it some gas and she fired right up. I rode the wheels off it for a few minutes until she started starving for fuel. Gotta get that issue worked out, but I'm going to continue mapping out the ECM inputs and outputs so I can have a bypass solution.
If anybody cares I got the ECM inputs and outputs mapped out. It does a couple of things. Its the voltage regulator for the stator, It controls the locker in the rear end and distributes power to the electrical system. I figured out how to bypass it all, except the stator, using jumper wires. Developement is under way for a plug & play bypass harness equipped with fuseable links and a control relay for the locker system if anyone is interested. My only hurdle I guess is finding a voltage regulator to use.
  • 2 years later...
Hi Ahren, I am interested in your work as we have a 2005 ATP 330 that the ECM seems to have failed and was wondering how to do away with it. It has been showing hot for a while now off and on. I have deleted the diff lock and 4wd is automatic anyhow. I would be happy to just get it to start and run and charge the battery
    • By oxidized_black
    • By Sportsman500guy
    • By qcm413
      Hi,
      thank in advance
    • By colin james
      View File 2005 Polaris Phoenix 200 service manual
      This is the service manual  for the polaris phoenix 200 down load all chapters to have completed manual
      Submitter colin james Submitted 07/19/2018 Category Polaris ATV
    • By GatorHunter
      Thank you, and enjoy
      GH
      1985 Scrambler
      1985 Trail Boss
      1986 Scrambler
      1986 Trail Boss
      1987 Trail Boss
      1987 Trail Boss 4X4
      1987 Cyclone
      1988 Trail Boss 2X4
      1988 Trail Boss 4X4
      1988 Trail Boss 250 R/ES
      1989 Trail Boss
      1989 Trail Boss 2X4
      1989 Trail Boss 4X4
      1989 Big Boss 4X6
      1990 Trail Blazer
      1990 Trail Boss 250
      1990 Trail Boss 2X4
      1990 Trail Boss 2X4 350L
      1990 Trail Boss 4X4
      1990 Trail Boss 4X4 350L
      1990 Big Boss 4X6
      1991 Trail Blazer
      1991 Trail Boss 250
      1991 Trail Boss 2X4
      1991 Trail Boss 2X4 350L
      1991 Trail Boss 4X4
      1991 Trail Boss 4X4 350L
      1991 Big Boss 4X6
      1991 Big Boss 6X6
      1992 Trail Blazer
      1992 Trail Boss 250
      1992 Trail Boss 2X4
      1992 Trail Boss 2X4 350L
      1992 Trail Boss 4X4
      1992 Trail Boss 4X4 350L
      1992 Big Boss 4X6
      1992 Big Boss 6X6
      1993 250 2X4
      1993 350 2X4
      1993 250 4X4
      1993 350 4X4
      1993 250 6X6
      1993 350 6X6
      1993 Trail Boss
      1993 Trail Blazer
      1993 Sportsman
      1994 300 2X4
      1994 400 2X4
      1994 300 4X4
      1994 400 4X4
      1994 300 6X6
      1994 400 6X6
      1994 Trail Boss 2W
      1994 Trail Blazer 2W
      1994 Sportsman 4X4
      1994 Sport
      1995 300 2X4
      1995 400 2X4
      1995 300 4X4
      1995 400 6X6
      1995 Trail Boss
      1995 Trail Blazer
      1995 Sportsman 4X4
      1995 Sport
      1995 Xplorer 4X4
      1995 Scrambler
      1995 Magnum 2x4
      1995 Madnum 4X4
      1996 Trail Blazer
      1996 Trail Boss
      1996 Xplorer 300
      1996 Xpress 300
      1996 Xplorer 400
      1996 Xpress 400
      1996 Sport
      1996 Scrambler 4X4
      1996 Sportsman 4X4
      1996 Sportsman 500
      1996 400 6X6
      1996 Magnum 2X4
      1996 Magnum 4X4
      1996 Magnum 6X6
      1997 Trail Blazer
      1997 Trail Boss
      1997 Xplorer 300
      1997 Xpress 300
      1997 Xplorer 400
      1997 Xpress 400
      1997 Xplorer 500
      1997 Sport 400
      1997 Scrambler 4X4
      1997 Scrambler 500
      1997 Sportsman 4X4
      1997 Sportsman 500
      1997 400 6X6
      1997 Magnum 2X4
      1997 Magnum 4X4
      1997 Magnum 6X6
      1998 Trail Blazer
      1998 Trail Boss
      1998 Xplorer 300
      1998 Xpress 300
      1998 Sport 400
      1998 Scrambler 400
      1998 Scrambler 500
      1998 Xplorer 400
      1998 Magnum 2X4
      1998 Magnum 4X4
      1998 Sportsman 500
      1998 Big Boss 500 6X6
      1996 Sportsman 400
      1996 Sportsman 500
      1996 Xplorer 500 4X4
      1997 Sportsman 400
      1997 Sportsman 500
      1997 Xplorer 500 4X4
      1998 Sportsman 400
      1998 Sportsman 500
      1998 Xplorer 500 4X4
      1999 Sportsman 400
      1999 Sportsman 500
      1999 Xplorer 500 4X4
      2000 Sportsman 400
      2000 Sportsman 500
      2000 Xplorer 500 4X4
      2001 Sportsman 400
      2001 Sportsman 500
      2001 Xplorer 500 4X4
      2002 Sportsman 400
      2002 Sportsman 500
      2002 Xplorer 500 4X4
      2003 Sportsman 400
      2003 Sportsman 500
      2003 Xplorer 500 4X4
      A01CH50AD
      A01CH50AA
      A01CH50AB
      A01CH50AE
      A01CH50AK
      A01CH50AF
      A01CH50AJ
      A01CH50EB
      A02CL50AA
      A02CL50DA
      A02CH50AA
      A02CH50AB
      A02CH50AE
      A02CH50AK
      A02CH50AC
      A02CH50AD
      A02CH50AJ
      A02CH50AL
      A02CH50AM
      A02CH50AN
      A02CH50FA
      A02CH50AAEB
      A02CH68AA
      A02CH68AB
      A02CH68AC
      A02CH68CA
      A02CH68CB
      A03CL50AA
      A03CH42AA
      A03CH42AB
      A03CH42AC
      A03CH50AA
      A03CH50AA
      A03CH50AA
      A03CH50AA
      A03CH50AA
      A03CH50AA
      A03GJ50AA
      A03GJ50AB
      A04CL50AA
      A04CH42AA
      A04CH42AE
      A04CH42AG
      A04CH42AQ
      A04CH42AT
      A04CH42AV
      A04CH42AS
      A04CH42AR
      A04CH50AA
      A04CH50AC
      A04CH50AE
      A04CH50AG
      A04CH50AO
      A04CH50AQ
      A04CH50AR
      A04CH50AS
      A04CH50AT
      A04CH50AV
      A04CH50AW
      A04CH59AF
      A04CH59AH
      A04CH59AJ
      A04CH59AT
      A04CH59AV
      A04CH59AK
      A04CH59AL
      A04CH59AN
      A04CH59AW
      A04CH68AC
      A04CH68AF
      A04CH68AH
      A04CH68AJ
      A04CH68AT
      A04CH68AV
      A04CH68AK
      A04CH68AL
      A04CH68AN
      A04CH68AO
      A04CH68MB
      2004 Ranger 2X4 Parts Manual
      A04RB42AA
      2004 Ranger 4X4 Parts Manual
      A04RD50AA
      2004 Ranger 6X6 Parts Manual
      A04RF50AA
      A05CL50AA
      A05MH42AB
      A05MH42AG
      A05MH42AH
      A05MH50AB
      A05MH50AC
      A05MH50AG
      A05MH50AH
      A05MH50FB
      A05MH59AK
      A05MH59AN
      A05MH68AK
      A05MH68AN
      A05MH68AC
      A05MH68AS
      A05MH68AU
      A05MH68AW
      A05MH76AC
      A05MH76AU
      A05MH76AW
      A05MH68AP
      A07MH68MA
      R07RF68AD
      R07RF68AF
      R08RF68AD
      R08RF68AF
      2009 Outlaw 90 service manual
      Other Stuff
      Download Manuals HERE
      Some ATV manuals available in the downloads section at https://www.quadcrazy.com/files/
      Find them on on:
