So I dug my warrior out of storage replaced the carburetor with one off Amazon & it was running great. Last week it didn't want to start it would crank & I could smell gas but nothing. I replaced the starter,stator,solenoid,spark plug & coil & resistor but still not starting. Checked the stator and its at 30 ohms tried using starter fluid but nothing. I am completely lost and could use some help thank you
After I did a tune up it was struggling to start and my battery would die after five or six rides. So when I couldn't get it started I opted to just replace all the parts instead of one at a time. The only improvement I've noticed that it does sound sick when I try and start it
There is some danger in replacing parts, especially if they are chinese knock offs.  Does that one have a regulator/rectifier?  That would be my first suspicion, bet it's not putting out over 12V.
Yeah I agree with MarkinAR, its probably not re-charging the battery while running, so after a few rides the battery is low and there isn't enough power to fire the spark plugs when trying to start.
If you have a voltmeter, then check your battery voltage when it's not running (should be around 12.75v), then again when it is running (should be around 14v).
If you don't have one, then does it crank noticeably slower and headlights dimmer when it is struggling to start - that's how you can tell the battery is low without a voltmeter.
You can jump it with a car and car jumper cables if you're careful (negative to ATV frame and positive to ATV battery +) and if that works, then the problem is the charging system or battery.
    • By Tinkeringreg
    • By Arizona
    • By kaidella
    • By jhamrick75
    • By Mmessy83
      I recently purchased a complete lt230s for$50. It was missing the kick starter gears which I got off eBay for $18. I’m trying to install the gears which after reading different threads about having it timed. I have it all timed but now it acts like engine is seized up but I know it’s not. What could be going on??? Any insight would greatly be appreciated.
