1994 Polaris 300 2x4 project won’t start. Seems like we have spark and have tried straight starting fluid in cylinder and still not getting a fire.   Kind of has me stymied
  • 5 weeks later...
Just my 2 cents, but if you are trying to spray starting fluid into the carb and you can see that you have spark(and you know that you don't have it flooded)...
you could  try to take plug out crank it several times 1st-(good time to check spark again, and to make sure it wasn't flooded)
-pour a SMALL amount of gas into the spark plug hole
-Replace plug and try again cranking.... if it hits  and dies quickly try gas into the carb again-
-Try gas back in the carb again... if that doesn't work (and gas in the spark plug hole did)... you may have an issue with the inlet valve
    • By Frank Angerano
    • By Tinkeringreg
    • By oxidized_black
