  • Admin changed the title to Kawasaki Lakota frame same as Mojave?
The Kawasaki Lakota and Mojave are almost exactly the same from what I've read except for the engines and I think swing arms, suspension and a few other items. The Lakota has the Bayou engine I believe. Depends on year.
    • By marcosphoto
    • By mga
      I have a Yamaha Big Bear 400 4x4 2000.  I've posted on here about the frame being bent. Does anyone know what year frames are interchangeable? Also, would the frame from a 350 be the same as a 400? Would it matter if it was a 4x4 or 2x4?
      thanks for any help with this
    • By onequad
      i got a 93 400 Kodiak the frame on one side is rusted out.  is this a comin thing? was wondering if it worth the  tumble to put in a used one. I'm worried most of the bolts will brake. it don't look the rusted over all. just the part were the frame boke in half. do all kodiaks have the same frame
    • By justent_88
      Hello, im looking for some input on this situation i have. My 94 Mojave has no spark, and i have no idea what it is. Ive replaced/tested the magneto, the pickup coil, cdi, the ignition coil. Even the key and Killswitch. I haven't tested the harness its self, but i have tried another harness and still nothing. The only thing i can think of is the fly wheel itself. I have found a lot of metal shavings in the fly wheel and have cleaned it the best I could. But nothing happened afterwards. I am truly stumped here and hoping some of yous could shed some knowledge/ideas that could help get this thing to fire.
    • By jpz
      Hello all,
      I am working on a MXU 270 and having the hardest time finding information. I recently saw a youtube video that claims the MXU 270 is mechanically the same as the Bruteforce 300. Can anyone confirm?
