Suzuki King Quad 700 give it gas then it dies
By Eisaks777
hello, i have bpr bombaradier rally 200 2007 which has a lot of gasoline in the oil sump, it is 4 stroke. Has anybody had problem like this and which can be the cause and how to fix it. i rode it today at -2 degrees celcius if it helps.
By Patrik1543
Good day, I have an atv 150 raptor with a bemi engine from 2002, at least that's what the label says, the problem is that it doesn't have electricity, I bought it completely new and nothing works except the starter relay, so I'd like to make it my own and with my own hands, I just need you to help us get a diagram because I can't find anything on the internet that would answer my idea, the quad bike has a 4-pin cdi and a 4-pole rectifier and a digital tachometer.
By Clydaho
2022 Sector 550, 414 miles on it and the gas gauge reads empty. I topped off the gas and it didn't change.
There is no fuse that I could find. No access at the gauge cluster.
Has anybody removed the tank lid? Any tricks?
Any other ideas?
Thanks for any help,
Clyde
By Suzukiquad
I just bought two 2002 Suzuki LT80K. Do I need to mix the gas or use straight unleaded?
By ceedaman
Hello, I would like to ride my ATV in a field close to my house and I know where the owner lives but I've never been very good at asking for permission to ride in someone's field. I know they don't use the field at the moment and I want to come across respectful but it seems like people get offended so easily over simple questions. If you were going to ask, how would you start the conversation? I would like to build a respectful relationship as this person own quite a bit of land int he area.
