1997 Kawasaki Bayou 300 assembly of clutch cover
By Sportsman500guy
By Gwbarm
IMG_4910.mov There is some slack in there but most is taken up by the gear cover,if anyone with history with these machines has had the same problem, let me know your findings. Where i am now im looking for finding replacement honda gears on Ebay and try those. I suspect the original was replaced with aftermarket gears years ago and they just worse quality as the years go by.
By Ejwill
By motox88
Anyone have bad experience with these clutch kits? Looking to get one for an 80s quad that I have.
By mga
I get it, turn counterclockwise will decrease, turn clockwise will increase. My question is what exactly am i increasing or decreasing? Is it clutch pressure? In many videos i've seen it's always "turn counterclockwise" until you feel resistance then back off. Why is it always to decrease?
I'm just curious as to what exactly is going on when i turn that screw right or left. And, since there's no manual clutch to engage or disengage, what is going on inside?
Reason why i'm asking is while going down a hill in 1st gear, it appears to pops out of gear, but no neutral light, and if i stop, it's in 1st gear still. BUT, (always a but) if the engine is warmed up, it stays in 1st gear. The hill is too steep to use any other gear, so 1st with the brakes is the only way to go down.
