Air intake snorkel 0570-062
By jwh
I am new to this site. Now down to business, I have been given a Kawasaki 220, tires are trashed and it has been setting for a long time. Do I need a battery in it to find neutral? I know there is a neutral switch and if I shift down(7 times????) then up one using the neutral switch I should be in Neutral. As you see I am in a learning curve here ......coments welcome.
By Admin
Looking for Arctic Cat ATV VIN (Vehicle Identification Number) Number Decoders? Once you find your ATV VIN number off the tag on your Arctic Cat ATV, you can go to all kinds of websites that have VIN Decoders available. The best ones are backed by the Arctic Cat ATV manufacturer, however there are plenty of aftermarket Arctic Cat ATV VIN Decoder websites on the web. This topic will stay pinned and if you find any to add, please do it with a reply.
CARFAX https://www.carfax.com
By Coyote251
service manual - 2016 Can-Am Outlander L-Series
By Hagbard
Picked up a barn find that someone had already partially disassembled because the “motor locked up” but they never opened the case. Everything was bagged and labeled, and as I’ve mentioned before- I love a challenge ¯\_(ツ)_/¯
After a couple hours of fun with various pullers and hammers I managed to persuade the magneto/flywheel to come off. Hoo boy what a mess. Then I found an actual rats nest in the clutch cover. ಠ_ಠ
By killerklown
I received an additional parts engine with a 220 Bayou I purchased, but I believe it's a couple years newer than the ATV, Is there a way to decode the engine serial number like we can with VIN numbers?
