  • Ajmboy changed the title to 1985 Suzuki LT50 No Spark
Thanks but I have 2 new aftermarket coils that don’t work. I was thinking maybe this Lt50 needs a specifically wound coil for it 🤔Excellent spark from the stator wire to ground, but that’s it . Thanks again
a 2 wire coil is pretty much a 2 wire coil.  I'd look at the run/stop/run switch, make sure the coil is grounding on a clean surface, etc.  Likely to be an electrical gremlin if more than 1 coil won't spark.
    • By Mhatayas
    • By Kawasakibayounospark
    • By carkivey3
    • By opnea
      Recently picked up a 1991 Lt230e for repair. Compression is a little low Id say, around 80psi, I also have spark but the spark is odd . When cranking the spark is a constant arc. I’ve got it to sputter but never fully turn on. I believe the spark is my issue, being constant and not detonating at the right time. I’m not sure whether this issue is an electrical fault like some missing ground, a faulty cdi, or a timing issue. Any ideas where I should start?
