You can see in the pic the lower cable is slightly pulled.  I'd loosen both off and make sure the brake arm moves freely.  If it moves freely, then look at the cable.  I'm assuming the lower one is a hard line that goes to the foot brake?  Is it slightly depressed?  Maybe some lube and everything that moves and it'll come back to life.  either that or the rear shoes are so worn that the cam is stuck between the shoes.
    • By jwh
    • By mans
      Were is the neutral safety switch on 03' Kodiak 400 4x4 . How xan i check it to see if it's good for a no neutral light no power to machine. Ty
    • By oxidized_black
      1985 - 1990 Suzuki LT230 & LT250 service manual
      https://www.quadcrazy.com/files/file/532-1985-90-suzuki-quadrunner-lt230-service-manual/
      1987 - 1998 Suzuki Quad Runner 250 & King Quad 280 service manual
      https://www.quadcrazy.com/files/file/268-quad-runner-250-king-quad-1987-1998-service-manual/
      1987 - 2006 Suzuki LT80 service manual
      https://www.quadcrazy.com/files/file/89-1987-2006-suzuki-lt80-service-manual/
      1987 Suzuki LT500R Quadzilla service manual
      1988 - 1992 Suzuki LT250R Porting Instruction
      https://www.quadcrazy.com/files/file/90-1988-1992-suzuki-lt250r-porting-instructions-manual/
      1988 - 1992 Suzuki LT250R Quadracer service manual
      https://www.quadcrazy.com/files/file/91-1988-1992-suzuki-lt250r-quadracer-service-manual/
      1988 - 1992 Suzuki LT250R Tuning Guide Instruction
      https://www.quadcrazy.com/files/file/92-1988-1992-suzuki-lt250r-tuning-guide-instructions/
      1999 - 2004 Suzuki King Quad 300 service manual
      2002 - 2007 Suzuki 500LTA service manual
      2002 - 2009 Suzuki LTF250 Ozark service manual
      https://www.quadcrazy.com/files/file/94-2002-2009-suzuki-ltf250-ozark-service-manual/
      2003 Suzuki LTZ400 service manual
      2006 Suzuki 50LTZ Quad Sport service manual
      2004 Suzuki 250LTZ Quad Sport service manual
      2005 Suzuki LTA700 King Quad service manual
      2007 Suzuki 90LTZ Quad Sport service manual
      https://www.quadcrazy.com/files/file/97-2007-suzuki-90ltz-quadsport-service-manualpdf/
      2008 Suzuki 400FLTF King Quad service manual
      https://www.quadcrazy.com/files/file/98-2008-suzuki-400fltf-kingquad-service-manual/
      2008 Suzuki 750 King Quad service manual
      https://www.quadcrazy.com/files/file/99-2008-suzuki-750-kingquad-service-manual/
      2009 Suzuki 400LTZ Quad Sport service manual
      https://www.quadcrazy.com/files/file/100-2009-suzuki-400ltz-quadsport-service-manual/
      ALSO CHECK SUZUKI ATV SERVICE MANUAL DOWNLOADS
      Please visit the downloads section for ATV manuals at https://www.quadcrazy.com/files/
      Also available at:
    • By gt_jacket
      Hi,
      I have an 04 bear tracker, with a minor starting quirk. It starts in gear with brake in.  Neutral and Reverse lights work.
      But when trying to start in neutral, there is no click or attempt to start with the push button.
      However if i pull up on the shifter (not hard enough to shift into first though) the neutral light goes off and the start button works and it starts fine.
      All gears shift fine with no issues,  has anyone seen this before?  Just wondering if it is a bad sensor or something needs adjusting.
      Thanks for any help you can provide.
    • By Randel1
