  • Admin changed the title to Polaris 425 Magnum Starting Issues
Can't be an electrical related issue if it runs on ether. You have narrowed it down to a fuel delivery problem.
How do you know its getting fuel?
Edited by MarkinAR
check compression, timing and valve lash- those can contribute to your symptoms.  i agree with@MarkinAR , cant be electric related or it would not fire period.  had you tried cleaning your old carb before you bought a new one?  the choke is another thing id check- if its stuck open, itll flood the motor enough to not run
Check the plug boot, it has a resistor in it and it can go bad, should read about 5300 ohms. When it starts to get bad, it can deliver a weaker spark which will likely be enough to fire up on ether. The coils rarely go bad, it's usually that plug boot resistor and you can buy it and/or the boot and wire without the coil. The dealer will likely try to sell you the boot/wire/coil assembly.
I just went through this issue, running fine one day, then no start next time.
Ray
Edited by RAYAR
    • By Tinkeringreg
    • By Dumass
    • By Trent Finnessey
    • By DPDISXR4Ti
      Thanks...
    • By kaidella
