hi guys I'm back again lol. Last year I bought a polaris 500 magnum had some issues we banged our heads together and Finally fixed the problem well im back. So it ran fine for a long while then just lost spark. So bought the same exact stator and pickup coil I bought b4 boom fired right up now the kicker runs for 7 sec then dies ok so hear we go with what I've tried
Gap in throttle good unplug black wire did it no go
Reflowted bowl just incase fuel stopped not and didn't fill up not it
Bought a new fuel pump stator pick up coil twice now
Bought cdi box nothing
But if you hold it half throttle when you start it runs for ever
So new spark plug new wire
Coil nothing ill take any ideas besides fuel even mention it
I would be very interested in the outcome of this problem as I have run into the same thing, no spark with a Chinese machine being the with a 09 Kazuma 500 Jaguar.
I pray someone out there knows the answer.
Willing to bet the parts that you replaced were done so with chinese junk from ebay or amazon, correct?  Put the OEM parts back on.
next step, check the timing.  sounds a lot like timing is retarded a couple teeth.  I'd check timing and the timing chain lash because they only jump time when the chain is stretched.
I didn't mention the most obvious and most likely issue of fuel because I'm pretty sure you said not to mention it.
    • By oxidized_black
    • By Kawasakibayounospark
